https://nodered.org/ Seems like a good flexible GUI for IoT programing.
It is provided by default on Open Energy Monitor and GrovePi so there is some examples to look at.
I am also using it in https://github.com/chrowe/ansible-pi
I figured out how to send data to FarmOS
Example code https://gitlab.com/snippets/1701266
Now trying to get GrovePi sensors working. I created
https://github.com/DexterInd/Raspbian_For_Robots/issues/168 but maybe this something that comes with Raspian.
I got it working!
Pretty simple once you figure out what is needed.
Starting from a basic GrovePi setup like http://forum.goatech.org/t/grovepi-basic-setup-reading-sensor-values/96 all I had to do was
From there you should have some new GrovePi nodes in Node-RED and the options are pretty clear.
I am starting to work on a demo video. If you want do see that let me know, it might encourage me to get it done faster
Ok, I discovered by accidentally unplugging this pi that Node-RED will not automatically restart unless you run sudo systemctl enable nodered.service
as stated on https://nodered.org/docs/hardware/raspberrypi
Hi, Iām new to the forum and just wanted to introduce myself. I couldnāt find a āmeet and greet sectionā so I posted it in a section I have specific interest in.
Iām a freelance software/hardware developer in South Africa. I grew up on a farm and itās still a passion, therefore the interest in AgTech. Iāve been tinkering with some farm IoT ideas for a while and looking for like minded individuals. Happy to have found this forum.
I have put together a Raspberry Pi IoT gateway running Node-Red to connect with (potentially) various sensors on low cost cheap hardware via MQTT. So far I have used the ESP8266 running https://mongoose-os.com/. A very cool open source embedded OS.
Wow this is so cool, Iāve never seen that before. Iām super impressed. If you get something cool up and running that ag-specific in itās orientation using Node Red, Iād love to see a walk through video (even a poorly edited one). @mdc you should check this out - watch the video at the beginning of the node red page.
Check out http://farmhack.org/tools/collecting-sensor-data-farmos-using-grovepi-and-node-red for a tutorial on how to do this with a GrovePi. I also have a video of this
