Installing and using Docker on Raspberry Pi
The following is a very basic intro to running applications inside Docker containers on a Raspberry Pi, intended for someone who has never used Docker before, but wants to try it out. This was also my first step into Docker on Pi, so I documented it as I went along.
There are a few different tutorials out there for installing Docker on a Raspberry Pi. I found this one works well, and follows the same basic instructions as is recommended for installing Docker on a Linux PC.
These are the commands I ran on the Pi (in case that site disappears):
sudo apt-get install apt-transport-https \
                       ca-certificates \
                       software-properties-common
curl -fsSL https://yum.dockerproject.org/gpg | sudo apt-key add -
apt-key fingerprint 58118E89F3A912897C070ADBF76221572C52609D
sudo add-apt-repository \
       "deb https://apt.dockerproject.org/repo/ \
       raspbian-$(lsb_release -cs) \
       main"
echo "deb https://apt.dockerproject.org/repo/ raspbian-jessie main" | sudo tee -a /etc/apt/sources.list
sudo apt-get -y install docker-engine
You can test that it’s working with the following command:
sudo docker run hello-world
To start playing with putting your app in a Docker container, first create a file called Dockerfile with the following content:
FROM resin/rpi-raspbian
This simply means we want to create an image that inherits from the resin/rpi-raspbian image, which provides us with a basic Raspbian environment inside a container. (There may be better options out there for base images - this one worked quickly. Curious if others have experience or suggestions around this…)
Then, we’ll build it into a container image called “mycontainer”:
sudo docker build -t mycontainer .
When that’s done, you should see it in the list of images that are available on your system:
sudo docker images
To start up a new container based on that image, run:
sudo docker run --rm -it mycontainer
This puts you directly into a bash shell within the container.
I also tested a simple Python 3 container, which puts you into a Python shell. Just change your Dockerfile to:
FROM python:3
Then rebuild and run.
The above is just a very simple way to get started with Docker on a Raspberry Pi.
In most cases, you will want to build out your Dockerfile to include everything necessary to run your app, and set it up to auto-start the container on system boot.
The official documentation for Docker goes into a lot more detail. This page has a good example of how to set up a Flask server inside a Docker container: https://docs.docker.com/get-started/part2/ - which helps to demonstrate how a Dockerfile works and what the whole process of “Dockerizing” an app looks like.
To access the Pi’s GPIO within a Docker container, start with this simple Dockerfile:
RUN apt-get update
RUN apt-get install -y wiringpi
That simply creates an image based on Raspbian, updates package repos, and installs wiringpi.
Build and run it with two extra arguments in docker run:
sudo docker run --rm -it --cap-add SYS_RAWIO --device /dev/mem mycontainer
The extra arguments (--cap-add SYS_RAWIO --device /dev/mem) tell Docker to give the container access to the host system’s GPIO hardware directly.
Then, in the bash shell, read from the GPIO to test that it’s working:
gpio readall
To turn on GPIO pin 24:
gpio -g mode 24 out
gpio -g write 24 1
And off:
gpio -g write 24 0
Just running curl -sSL https://get.docker.com | sh from https://www.raspberrypi.org/blog/docker-comes-to-raspberry-pi/ worked for me to get docker installed.
