Some tips about Claude for vibe coding
If you are vibe coding, or your a coding using claude, you may have learned some of these things yourself but this is an excellent list worth reading. Several things I can confirm through my own experience:
  1. Actively use compression - don’t wait to auto-compress
  2. Keeping sessions alive matters a lot. And (I didn’t know) you can pick up an old session using –continue!
  3. Having 5 agents running on a similar context base costs the same as running 1 - so multi-agent tasking is actually really key to do!
And many more.
Also, now that they accidentally leaked this code and someone converted it to python… Anthropic’s AI harness (which is amazing) is now basically open source so it’ll make it’s way into open source versions and thus make every other model better and feel like running claude, probably in the next 1 - 2 months. Yay!
The days of locally run, super powerful, awesome harnessed AI is coming and I’m personally very excited about that.
complimentary resources:
Claude Code Unpacked : A visual guide](https://ccunpacked.dev/)
Re the video (super informative): in addtion to what you mention above re parallelism and compression, his note at the 8.20 mark about the settings.json file seems pretty key
